Tool storage - Specifically hand planes http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=14326 |
Page 1 of 2 |
Author: | Andy Matthews [ Thu Nov 01, 2007 4:03 am ] |
Post subject: | |
I've been trying to think of a convenient way to store my hand planes above my bench, but I'm having a hard time coming up with something nice. It's not like I've got many, just a number 6 and a block, but I want them to hand, yet safe when not in use. Any suggestions chaps? A googling has come up with nothing really... Cheers |
Author: | Rick Turner [ Thu Nov 01, 2007 4:08 am ] |
Post subject: | |
Traditional is on their sides with some sort of arrangement so that nothing touches the blade. Very handy to just reach up and find the handle right there... |
Author: | Andy Matthews [ Thu Nov 01, 2007 4:09 am ] |
Post subject: | |
Is there any specific reason to leave the plane on it's side when the iron's well retracted? I tend to retract the blade when not in use any... |
Author: | Rick Turner [ Thu Nov 01, 2007 4:14 am ] |
Post subject: | |
Why bother? Just store it in a manner that the iron doesn't touch anything unless you just love spending extra time fussing with tools. I'd rather grab it and use it. |
Author: | letseatpaste [ Thu Nov 01, 2007 4:18 am ] |
Post subject: | |
You might also consider that whatever you store above your bench may some day fall onto whatever is in progress on your bench. One of these days I'd like to build one of these for all my handtools and measuring things, plans/article available from Fine Woodworking. ![]() |
Author: | Andy Matthews [ Thu Nov 01, 2007 4:19 am ] |
Post subject: | |
[QUOTE=Rick Turner] Why bother? Just store it in a manner that the iron doesn't touch anything unless you just love spending extra time fussing with tools. I'd rather grab it and use it.[/QUOTE] Because I set my planes differently for each job. This way I don't grab a heavy set plane and use it for the wrong task. It forces me to dial the plane properly each time. |
Author: | JohnAbercrombie [ Thu Nov 01, 2007 4:23 am ] |
Post subject: | |
I'm a bit paranoid about stuff falling off the wall on to my work, so I don't keep a lot of tools hanging above my bench. For a few planes, one option I've used is a custom-fitted softwood shelf (with a lip) - if you rout or chisel a shallow dado in the shelf (where the blade would rest), you can leave the plane blade in the working position. Just use small metal angles, or a cleat, to attach the shelf to the wall BTW, this is a bad idea if your shop is humid or gets condensation in cold weather, since you can get rust on the plane sole. But, you have humidity control in your shop, right? ![]() These days, I have a wide, shallow drawer under the bench top, and I store most of my planes on their sides in there. Cheers John |
Author: | Howard Klepper [ Thu Nov 01, 2007 4:25 am ] |
Post subject: | |
Carpeted shelf. |
Author: | Dave Stewart [ Thu Nov 01, 2007 4:37 am ] |
Post subject: | |
Great stuff Todd!....love to see a well organized collection of beautiful tools. (Since each plane has a specific spot, did you relieve a pocket underneath for the protruding blade?) |
Author: | Howard Klepper [ Thu Nov 01, 2007 4:40 am ] |
Post subject: | |
Very nice, Todd. |
Author: | WaddyThomson [ Thu Nov 01, 2007 4:47 am ] |
Post subject: | |
I built a limited form of the above from a drawer that was a little off square from a kitchen cabinet I made. I just made a second one with the same dimensions for the outer door, and put a flap on the inside. The Chisel rack is removable, and can sit on the bench, though I don't find myself doing that. The planes sit on thin cork with a gap where the blade goes. Wide gap so I don't have to look too closely when putting them up. It works great, but is not big enough. |
Author: | SteveCourtright [ Thu Nov 01, 2007 5:09 am ] |
Post subject: | |
I am with Howard, but on a low shelf under the bench. Dropping a plane is a bad thing. Mine are on a piece of leather so the blade can be left where I like it. And I use different planes for hogging and fine work so I can just grab what I need. |
Author: | Arnt Rian [ Thu Nov 01, 2007 5:58 am ] |
Post subject: | |
Here's how I do it. I put a thin piece of wood on the edge of two of the shelf where the planes rest so the sole of the plane only touches the shelf at the toe and the thin piece of wood at the heel, thereby suspending the middle part off the shelf to protect the cutting edge. Longer planes are stored vertically, but tip away enough from the wall so the irons never touch the wall. Violin planes are stored in a separate box so they don't disappear among the clutter. Router planes, plow planes and so on are just stored vertically on a flat shelf. I now also have some more fancy infills and specialty planes in that shelf... I like the open, easy access of this system, and I have not had any accidents with dropped planes etc. since I put this together about 7 years ago. ![]() |
Author: | burbank [ Thu Nov 01, 2007 6:09 am ] |
Post subject: | |
I'm with John - nothing heavy above those soft spruce tops. My planes are on a carpeted shelf to the right of the bench. I've seen a couple shops where there was NOTHING above the bench. Waddy, Are those CURTAINS I see in your shop?! ![]() |
Author: | WaddyThomson [ Thu Nov 01, 2007 6:28 am ] |
Post subject: | |
[QUOTE=burbank]Waddy, Are those CURTAINS I see in your shop?! ![]() Indeed they are, but you probably don't want a close-up of them. They are old, old, old, and if I put any undue stress on them they will tear, usually along a rot-line. No inside woodwork on the windows, and these are easier to vacuum than blinds. |
Author: | JohnAbercrombie [ Thu Nov 01, 2007 7:09 am ] |
Post subject: | |
Man- I'd have a real problem with some of the really organized tool cases in the pictures....no room for more tools!! ![]() ![]() "Of course I need this, honey." ![]() John |
Author: | FishtownMike [ Thu Nov 01, 2007 7:42 am ] |
Post subject: | |
I just have a trough attached to the side of the work bench that has a piece of carpet on the bottom so i don't damage the blade when i sit it in there. That way they are close at hand. |
Author: | BlackHeart [ Thu Nov 01, 2007 3:02 pm ] |
Post subject: | |
Oh yea, thats about what I need, a little bigger, for ALL the tools. Need to get them veritical instead of lying on every available horizontal surface. I was going to build 3 toolboxes for all the stuff, but maybe now I wont have to! I use a peice of packing foam to rest the plane on, but leather would work well also.Just remember to always put it there when your done. |
Author: | WaddyThomson [ Thu Nov 01, 2007 3:24 pm ] |
Post subject: | |
All the planes are sitting on cork with gaps where the blades are..... It was big enough for all my guitar stuff when I started. Now? T.A.S has overwhelmed it. |
Author: | TonyFrancis [ Fri Nov 02, 2007 8:14 pm ] |
Post subject: | |
Hey Arnt, Your berg handles sure look sweet. Are you taking orders? |
Author: | Arnt Rian [ Fri Nov 02, 2007 9:18 pm ] |
Post subject: | |
Ha-ha, those handles are nothing fancy! In fact I was getting ready to make some new ones, I have a bunch of chisels without handles and at least 15 of these Scandinavian classics with various shop made handles that I was going to rehandle. I got some very nice masur birch, and I had the stock prepared to a nice octogonal shape, cut up and ready for the lathe. Then the lathe motor died... That was about a year ago, I haven't gotten around to doing anything about it; it is one of those projects... |
Author: | Kim [ Fri Nov 02, 2007 10:43 pm ] |
Post subject: | |
I am for storing planes sole down on cork or carpet, preferably cork. Dimensionally speaking, the finest steel in your shop, possibly the world, is the edge of these cutting tools. A high carbon content is needed in this steel to make them hard enough to withstand the rigors of cutting wood, but it also invites corrosion. The corrosion is of course accelerated when such fine high carbon steel is exposed to moisture laden air and the effects will dull an edge quick smart and lead to excessive blade wear. By leaving the blade proud of the soul, storing unadjusted from the workpeice and allowing the edge to sink into the cork, it restricts exposure to the air. It is the same deal with static machinery such as tablesaws. You can apply all kinds of concoctions to inhibit corrosion if you like, but your first step should always be to place a coversheet over them when not in use. Once again, this is to restrict exposure to air. This goes a long way to slowing down the affects of that never sleeping rust. Cheers Kim |
Author: | Jim Kirby [ Sat Nov 03, 2007 12:43 am ] |
Post subject: | |
On the wall behind me (bench is freestanding) This is supposed to have a double layer of doors like Waddy's smaller one, but I haven't gotten around to it yet - it detracts from instrument building time! (It needs a few hangers for spokeshaves on the back of the main case above the top shelf, too.) ![]() |
Author: | Howard Klepper [ Sun Nov 04, 2007 5:28 am ] |
Post subject: | |
I have a set of Swedish chisels from a company named Janport that look exactly like Berg. Have you heard of this company? |
Author: | Arnt Rian [ Sun Nov 04, 2007 5:54 am ] |
Post subject: | |
No Howard, I have not. Are you sure they are not 'Jernbolaget'; those were made in Eskilstuna, Sweden just like Berg and look similar. |
